I looked up the material safety data sheets (MSDS) for various Castrol Oils as they have the ZDDP concentrations on them (as a range in Section 15).
GTX 20W-50 High Mileage - 1.38 to 2.74 (I think these are in %)
GTX 20W-50 "Low Mileage" - 0.69 to 1.36%
GTX 20W-50 Synblend - 0.69 to 1.37%
Edge 20W-50 for Classic Cars - 0.57 to 1.14%
According to the oil writeup at Moss Motors,
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Which oil should you use after the initial 20-30 minute break-in period?
You have two options. You can use an oil formulated for vintage engines. They have the appropriate levels of ZDDP (0.12% or 1200 PPM seems to be an average). They also have additional detergents and anti corrosion agents to help protect the engines that tend to sit for long periods of time.
If you prefer, you can use an API SM oil with 0.08% ZDDP, and add ZDDP to it. Mix it carefully to obtain the desired 0.12% ZDDP by weight (1200 PPM). Remember that levels of ZDDP over 0.14% (1400 PPM) will cause chemical corrosion of the tappet and lead to increased wear over time.[/QUOTE]
So, it seems as though the GTX 20W-50 High Mileage has the most ZDDP, and all the oils listed above have an appropriate concentration of ZDDP without adding more.
------------Keoke
