You know you drive a beater if....
You know you drive a beater if:
<ul type="square">
[*]Your rear fenders have lots of dings OUTWARD from tools and spare parts flying around in the trunk when you corner.
[*]You car has the "keyless entry" feature. Both locks are broken and unusable.
[*]You double the book value of your car when you fill the tank.
[*]Nobody wants to steal it or even brush up against it.
[*]It was stolen once and found two blocks way, on the same street.
[*]Curbs are minor inconveniences and in no way limit the paved surfaces your car has access to.
[*]You drive through an exclusive section of town the cops ALWAYS follow you.
[*]Your car uses more "other" fluids than gasoline.
[*]You think you can get "another hundred thousand out of it easy".
[*]After a minor fender bender with lamp post some stuff that was stuck or broken starts working again.
[*]It was broken into but nothing was taken.
[*]You don't need a change holder because coins stick to the vinyl repair tape on the seats.
[*]You lose the stop-light challenge to a 14-year-old on a moped.
[*]You cross your fingers every time you try to start the car.
[*]While waiting at a stoplight, people run up asking if anyone was hurt.
[*]Traffic reporters are starting to refer to you by name when discussing morning tie-ups.
[*]You judge suitable parking spaces by the degree of downhill slope.
[*]You have the local towing company on speed-dial.
[*]The engine catches fire and you don't notice anything wrong until the firetruck pulls you over.
[*]Your entire car isn't worth the minimum insurance deductible.
[*]The city sends you a notice requesting that you remove the 'abandoned vehicle' from your driveway.
[*]Every time you start your car, the smog index jumps a whole point.
[*]The 8-track tape deck finally eats your last tape.
[*]If something sounds funny, you turn up the radio real loud until you get home.
[*]You wait until the car is running before you fasten your seatbelt.
[*]You pull off the road to pick up the homeless psychopathic hitchhiker and he just gets wide-eyed and says "Uuhh, no way man..."
[/list]
and the best:
You give it away when you are done with it.
You CAN'T give it away when you are done with it.
"Days gone by" You mean yesterday? Great List. Would do Foxworthy proud, though I don't think rednecks drive LBCs. Come to think of it, is there a Brit equivalent to a redneck? A teaneck maybe?
My first reaction was to post a decidedly non-PC retort... Instead I'll just sit on me mits.
....When you say MPG,you're not referring to gasoline.
.... You give it away - & they bring it back the same day
- I was thinking of Uncle Buck & the "Beast" as I read that.
hehehehehe... Doc... What's on yer mind? I want to hear the "non-PC" comments myself - get off those mitts!
But, yeah good one's. I drive 4 beaters!
You describe your car as "reliable".....
It reliably breaks-down every 14 miles! /ubbthreads/images/graemlins/driving.gif
JACK
lmao
I had an old Wagoneer that would probably meet 90% of those.
sounds like some of my cars.
How about
There is a bungiee cord that keeps the passenger door from flying open and killing pedestrians in a left turn.
there is a hockey stick in the back to prop open the hatch and /or hood
there is a hammer on the passenger floor to be used in the event of finding the dead spot in the starter
you have bailing twine tied around a wiper arm then routed in a loop through the side windows.
there is a garbage bag duct taped over the hole where a window used to be
your version of a two tone paint job is the different colored fender and door from the junkyard
your version of "gold emblems" is the yellow paint pen they wrote on the different colored fender and door with at the junkyard
I refuse to comment on how many apply to me personally, but I will say that I have indeed witnessed each and every one first hand.
They've all ('cept for the string controlled wipers thing - genius tho - I just pulled a wiper arm and used my hand out the window to wipe it) applied to me at on point or another.
[ QUOTE ]
Hmmmm.... then there's the water pistol for a windshield washer....
[/ QUOTE ]
Personally, I like the episode of Mr. Bean where he uses the window washer on his Mini to rise his teeth after brushing them on his way to work.
I should add one I developed for my Jeep.
"Hanes" brand CV joint boots.
