blumagnet
I realize I may be beating a dead horse, as there has been a lot of input regarding electronic ignitions on this forum. However, I am wondering if there have been any new technological advancements since some of these older posts. I am planning on installing a Flame Thrower distributor in my 1275. I have a Lucas sport coil, but after reading some of the older posts, it sounds as though replacing that with a Petronix ignition coil at the same time wouldn't be a bad idea. It also sounds like I will need different plug & coil wires than the stock Lucas replacement wires & cap I have on hand (right angle, but the new distributor has the straight cap); any suggestions which wires are best? I would like to think this is the last journey through the ignition system I may need for a while & would like to upgrade to the most reliable modern technology out there. What do you think is the best combination of ignition components? What about plugs? I have been using NGK BP6ES with better results than Champion N9Y and wonder if there are even more advanced replacements (EC3?)
Apologies in advance if I have insulted any purists by suggesting non-stock alternatives...
