Hi all,
My TR3A is "TS 77971 LO". It came to me with an overdrive switch on the dashboard, but a non-overdrive transmission. It was obviously switched out at some point by a previous owner. Last fall I went to an estate / yard sale and bought the transmission in the pictures along with a spare engine. The owners could not provide any history or information on it.
I am pretty sure that this is an "A-type overdrive, but I am not sure about the rest of the transmission that is attached. There are several things that don't match the pictures I find on this forum or in pictures in the restoration books.
1. The flange on the back that attaches to the driveshaft is square instead of round.
2. The casting is shaped different on the left side by the clutch lever and on the right side by the grease nipple.
It is marked as TS 30261 (possibly TS 80261). The casting has several other marks on it "2D 59-- /", "60184", "61268", and "302551".
Questions:
1. What do I have here?
2. Will it work in a TR3A
3. How do I begin examining / testing it to determine if it is worth installing. I have downloaded what looks like an excellent document from Buckeye Triumphs that discusses overdrives, but I really don't want to tear this apart if it is not necessary.
4. Should I try to swap the whole unit into my car, or just concentrate on adding the overdrive to my existing transmission.
5. There is a crack in the top casting by the shifter. Could this be welded or should I look for a replacement part.
Thanks
