My xk8 convert. just started giving a message 'bulb failure'. HOWEVER, its only when you do TWO of the following: right signal and brake, right signal and lights on, lights on and brake. Does not have a problem if I only do ONE of these things. No fuses blown and no bulbs blown. Is it a relay? fuse? bulbs, taillight assembly? Help please...
Hi Guest!
