xj6 bonnet latch help
eschneider
Finally getting around to working on the '79 XJ6L I bought this summer for $150.
PWDA valve failed. The $150 jag is now an $1150 jag after repairs to the garage door.
So, besides the brakes, the other big concern is the bonnet latch. There is the male latch in the engine compartment, and the female recepticle in the bonnet itself. The recepticle seems to have either been cut out or worn away. What's it supposed to look like? here's mine:
LarryK
There should be 2, one on each side? They should be the extended tapered bolts with a slot and nuts for adjustment. The receptacle in which it goes will slide around the tapered head of the bolt. Also, there will be a safety catch in drivers quarter of hood by w/s wiper.
Part # JA-12179 for missing part JA -HHB2440BA for safety catch Part #s from https://www.xks.com online sight. Put in #s and they should come up.
eschneider
eschneider
Bingo! Thanks for the advice and the link - you nailed it.
Geez, I love this car more and more as I work on it.....
LarryK
You will have to have a captive nut welded into the bonnet to screw the catch pin in and adjust. Check threads so they match your part.
eschneider
eschneider
Yeah, after I understood what I was looking at, it was easy to figure out what was supposed to be where.
Turns out the captive nuts were the only thing missing - they tore out of the sheet metal of the underside of the bonnet. The spring loaded pin assy's were actually still in the latches -- when I pulled the hood release cable, they went -sproing- and shot across the driveway!!!! (found 'em, thanks)
So now I just need to attack it with a welder and some spare nuts (pun intended) I'm planning on having to reposition things a few dozen times in order to get the position and angle correct.....
LarryK
That'll be the first Jag that isn't a head banger!!! I remember working on my first XK140 and that d**n bonnet would always in the way. Then a 120 and up thru the XJ6s and V-12S. But, T-Birds and Vettes were the same.
R For Sale For Sale 1990 Jaguar XJ6 Jaguar Classifieds 0
E 1996 XJ6 Jaguar 1
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
W XJ6 Series I bumper swap to Series II Jaguar 0
V 89 XJ6, How to adjust front camber? Jaguar 2
A For Sale 1986 jaguar xj6 Jaguar Classifieds 0
S XJ6 Mk1 clutch slave question Jaguar 0
SherpaPilot Wiring Harness for XJ6 Jaguar 1
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
C tachometer for XJ6 Jaguar 0
Marvin Gruber XJ6 engine swap into XK 150 Jaguar 4
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
krswen Question about XJ6 cam covers Jaguar 6
J Question about Series III XJ6 Motor in E Type? Jaguar 2
smaceng Help with a XJ6 [sort of] Clutch Jaguar 3
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
W Removing wiper arm on 74 XJ6? Jaguar 0
B '72 XJ6 Door Seal Installation Jaguar 2
D XJ6 series III front end rattle Jaguar 5
D XJ6 SIII, idle adjustment Jaguar 7
T 10000k HIDs for 96 XJ6 Jaguar 4
D 85 XJ6 brake fluid reservoir leak Jaguar 4
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
D XJ6 Seat Removal Q. Jaguar 5
D 85 XJ6 No start, coil problem. Please Help Jaguar 11
K 72 Jaguar XJ6 4.2 litre motor reliability? Jaguar 4
CZ_Dave A Redneck Jaguar XJ6 Spotted 9
CZ_Dave A Redneck Jaguar XJ6 Jaguar 2
C Remove/Install New '93 XJ6 Door Lock Actuator Jaguar 0
C 1999 xk8 steering wheel swap out '93 xj6 Jaguar 3
W Removing windows in 74 Jaguar XJ6 Jaguar 1
R Jaguar XJ6 Door Locks Jaguar 8
B 85 jag XJ6 improve it's performance ? Jaguar 4
eschneider xj6 purge valve / air bleed valve Jaguar 4
dklawson Early '80s XJ6 Speedometer Transducer? Jaguar 0
M 87 Series III XJ6 Rough Running Jaguar 16
B Lead on xj6 series 1 / Chevrolet 350 Jaguar 0
M 1985 XJ6 Drivers door lock Jaguar 5
M Fuel Injection Problem on 87 XJ6 with 188,000 mile Jaguar 1
M 90 XJS and 87 XJ6 Trip Computer Problem Jaguar 2
TonyPanchot 1997 XJ6 Fuel Filter Location Jaguar 1
M Won't Start-1995 Jaguar XJ6-Why Jaguar 8
T Just bought a 1997 Xj6 L Jaguar 1
M Adjustment of XJ6 Door Locks with Keikert Solenoid Jaguar 5
tony barnhill Tackling My '85 XJ6 Again Jaguar 18
M 1994 xj6 ride height Jaguar 1
S 91 XJ6 rear shocks needed Jaguar 3
T Noise coming from my '89 xj6's rear Jaguar 24
brendanf Starting Problems Jaguar XJ6 1982 Sovereign Jaguar 10
T 1989 xj6 not starting [again] Jaguar 1
