Hi all.
My name is Pablo and I am from Spain and this is my first thread.
I own a XJ12 form 1987 and I got a problem with it.
The main issue is that once it is started the engine shuts off. I noticed that when it shuts off the 85 on the fuel pump relay loses ground. It doesn’t lose the 30 or the 86, it just loses the 85.
I checked the wire from the relay to the ECU at the trunk, the wire is in good condition, I anyway did a jump wire isolating the original one but the same thing happens. I read the entire manual but i can’t find any explanation why the ECU stops grounding the relay. I used the oscilloscope checking the 85 of the relay and the injector signal and fist the 85 ground dissapears and after a couple of seconds the engine stops and loses obviously signal to the injectors, so it is clear that only the relay pump loses activation. The next thing I am going to do is to check what happens with the 50 signla to the ECU and the positive and negative of the ECU but to be honest I thing that I am not going to find anything.
Have you ever have guys this problem before? Could the ECU be the problem?
Thank you and sorry for my english.
