Well, kinda. But the details vary significantly. My book shows that the HD8 uses a needle valve arrangement to set idle rpm instead of holding the main throttle plate open slightly (which must make synchronizing interesting); plus has a screw off to the side for adjusting mixture rather than a big nut like the stock H6 carbs do.<div class="ubbcode-block"><div class="ubbcode-header">Quote:] What kind of oil is "dashpot oil" and can it be purchased at Napa or Auto Zone? [/QUOTE]The type of oil is not critical at all; although the "weight" does make some difference. Since ordinary motor oil will work fine, yes, you can buy it at Napa or Auto ZoneRoyal_58 said:Do all SU carbs tune the same way?
