Deleted member 21878
thinking of adding a WOSP starter. just looking for some info on the wiring.
i am running a negative ground with an alternator. So i have a 10g wire that runs back from the alternator to the current starter relay to charge the battery.
1) do most use the stock relay/solenoid?
2) wiring layout to either use or not use the existing relay/solenoid?
Thanks
Thanks
