Trying to line up the motor mount bolts has always been a pain. This time when the engine went back in I used studs in the frame mount and then I just had to wiggle the engine mounts and then put washers and nuts on....simple.
I've had repair jobs on the Healey that were hard, time consuming, frustrating, backbreaking, confusing, tedious...my list goes on and on.
But the one job I 'will' find hard, time consuming, frustrating, backbreaking, confusing, tedious and yes, my list will go on and on...and I haven't even started doing it yet, is..."A NEW PAINT JOB!"
(and something tells me I'm never going to do it, at least on my own)
Paul
That's a good qualifier, as is Bob's comment about watching it roll away. I don't know if I could handle it (41st anniversary of its purchase was yesterday, Monday technically, since it's now after midnight).I've not done this, yet, but I gotta believe one of the worst jobs is selling your Healey (even if you want/need to).
Not a big job, but very frustrating...getting the bottom, inside mounting nut on the rear carburetor. Recently had to take that carb off to fix a sticking choke mechanism. I finally took an old 1/2" wrench, cut a "V" most of the way through the shank and bent it at a 45 degree so I could get it on the nut.
Griz
