Does anyone have any recommendation for the reinstallation of a worm gear to the short shaft on a tr3a? I had the worm gear pressed off one shaft and onto another at machine shop. It was the Nappa shop in Tacoma and they where helpful and did not charge me. At the tr factory they let the end of the rod run long and then pinned it over somehow, creating this bell capped fit on the end that holds the gear tight. However, when I had the worm gear pressed onto the new shaft. I am finding that recreating this penned end is not easy. I have used a ball peen hammer to get it going somewhat, but to get it tight is another issue. In fact, twice now as I have been peening the end over the worm gear has loosened up on the shaft. I am guessing because of the harmonic vibration. I took it back to the shop and they pressed it down again, but when I tried to finish the end, the worm gear starts to loosen. Now I wish I would have dropped it off and just paid them. I am confused on what to do. The last time I took it out we tried to create a flare/bell on the end by putting a ball peen hammer on the end as we pressed it. But, it would not flare. I am thinking these guys would rather see someone else come through the door. Oh my feelings. I must have turned into a sensitive guy.
