Nunyas
well, I double checked my info on needle sizes last night. The most popular size used in the Morris Marina 1798cc single HS6 carbureted engine was indeed ZH, and it used a "yellow" spring in the dash pot. The alternative "rich" needle was a SA. The second most popular needle used in this same application (again, according to Haynes) was TW with a yellow dahpot spring. The TW rich alternative needles was the SW needle.
I compared the documented profiles, and came up with the ZH being richer than the TW in mid-range engine speed, but the TW was richer in the top end.
I also compared the profiles of the "rich" needles. The top 1/3 of the SA needle's profile was identical to the TW, but the SA's lower 2/3rds was the richest of the 4 needles. The SW needle's profile was "middle of the road" in the mid-range/lower 2/3rd of profile, but the richest of the needles in top end.
anyways... I think I've narrowed down my list of parts to choose from quite a bit... sticking with the ZH needle for now... need to change the dashpot spring to "yellow"...
Are float bowl covers interchangeable? If I can get one with ventilation hook-up for a charcoal canister, buying one will probably be easier than potentially butchering the one I currently have.
