Went out to go for drive after work, and the Tunebug wouldn't start. I had electricity, choke out, pulled the starter and the engine spun and tried to catch. Pulled again and it spun for a few seconds. Pulled again and nothing. No click, no spin, nothing.
Cable pull to the starter is fine. Checked for continuity across the switch and when I pulled the cable, there was flow between the posts. Checked for continuity between the starter case and ground at the battery, and it was good. Removed and cleaned the battery ground connection at the firewall. Still nothing.
Next I tried turning the little nut on the end of the starter that is supposed to free the starter if it is stuck in the ring gear. This turned pretty easily, but didn't help. What else do I try? Pulling the starter looks like a real pain, so I'd like to exhaust my other options before going to that.
