Driver's side wiper (natch) is wonky.
If I position both wipers on the splines so they are in the correct parked position, after about 20 minutes of running, the driver's side will continue going until it's off the bottom of the windscreen (BJ7) onto the bodywork. The passenger's side will continue to work properly.
Originally, I thought the splines either on the wiper motor or wiper arm were stripped, but that doesn't seem to be the case. Instead, it seems like the wheelbox gets a mind of its own after a while and ignores the parked position and just keeps bringing the wiper arm past park.
Only thing I can think of is the spiral cable isn't meshing properly with the gear wheel in the box, but I dread getting myself upside down to check that out. Anyone else have any bright ideas before I experience a non-chemical head rush?
Hi Guest!
