Hi,
Just had new tires put on my steel wheeled TR-3B and still have a wobble around 50 mph.
Tire place said one wheel was not as good as others and they put it on left rear. Car still wobbles.
Had front end rebuilt about three years ago and car does not pull to either side. Front end was not aligned. One of the old tires on front left was showing wear on outside. The other front tire was normal wear.
I received feedback to have my drive shaft checked for balance and alignment.
I would appreciate other suggestions as to what may be causing this wobble.
I'm assuming the problem is my left rear wheel. Does anyone know where I could get two steel wheels fixed so they are perfectly round and in tolerance?
Thanks.
Paul
Thanks.
Paul
