Wizard Radiators
You would need the shroud or an electric fan.
Can someone tell me what thread pitch/diameter the temp. sensor is? If an electric fan should be run, I need to find a sensor that will thread into the radiator.
Thanks
Auto parts stores offer an external bulb electic fan switch that I've had good luck with.
Using an electric fan should be more efficient since at speed it is'nt needed and dos'nt run.
Kurt.
