wishfull thinking?
mtlman8
well, after getting the car to run and idle after 26 years.(wooo!hoOO!) I attached a vaccum gage to the intake only to find it very erratic:{ sticking valves right? so pull the head,valves,guides machineing ect...i'm not lazy,I swear, but is there any remody other tha pulling the head???
poolboy
I was able to clear up a sticky valve with 2000 miles of spirited driving and the addition of detergents to Shell gasoline.
I used common fuel system cleaners as "detergents"; the kind you'd find at Walmart.
M
mtlman8
THANK YOU!!! I was expecting "fairy dust" or "just pull the head, lazy" but I will try detergents.
M
mtlman8
I also heard spraying a little water into the carbs (while reving the engine)will create steam that helps also???
R
RonMacPherson
Marvel mystery oil..
Either dump a can in a tank full of gas and drive like you stole it, through two tank fulls, or remove the air cleaner and siphon the MMO through the air intakes at a fast idle. Then shut the car off and let it sit when the MMO is ingested overnight...
I myself enjoy the driving aspect more.
Mickey Richaud
+1 on the Marvel stuff.
Geo Hahn
I have seen (but not personally attempted) a professional mechanic who would strike the offending valve with a hammer whilst the engine was running. Had to choose the right moment I suppose.
YMMV, use at your own risk, professional driver on closed course, etc.
M
Member 10617
I saw a professional mechanic stike an offending valve with a hammer, but he determined that the problem was serious and that the car needed a valve job.
alfa33047
John, With the motor off, remove your valve cover, spray WD-40 onto the valve stems, shooting the WD-40 straw between the springs and spray on the valve stem. Bump your starter to rotate the motor, watch for any valve springs that seem to be lazy or stuck. If you do find a stuck valve (with the motor off) tap the stuck valve with a hammer until it return to the up position. You will find an excessive amount of valve clearence. While your valve cover is off, check your valve clearences (.012) intake and exhaust. Good Luck, Bill C. Mesa, Az.
poolboy
Maybe I didn't have a stuck valve then with all the talk about hitting the valve with a hammer. Mine moved, it just wasn't closing due to carbon. With the valve partially open when it should be closed, the Vacuum Gauge was pretty jumpy similar to what you see in Scenario 5
https://www.secondchancegarage.com/public/186.cfm
JPSmit Thinking about Solenoids Restoration & Tools 2
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Healey Nut What were they thinking Austin Healey 12
RickB Thinking of clearing out all Midget / Datsun stuff Spridgets 8
bugedd Thinking about winter time projects Spridgets 5
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
TRMark TR2/3/3A Thinking of a TR 2/3 ratrod project Triumph 23
R TR4/4A Thinking About an Electric fan Triumph 10
tinman58 TR2/3/3A Bad thinking? Triumph 25
jsfbond GT6 Thinking out of the box Triumph 2
danstr6 TR6 Thinking of selling my TR6 Triumph 4
G Thinking About My First Bugeye Spridgets 20
bugedd Thinking of some tunes.... Spridgets 10
Lukens Am I thinking right? Jaeger electric temp gage. Triumph 4
bugedd What am I thinking?? Spridgets 19
M_and_P Thinking of doing something funky with the Mini British Motor Corp 6
B thinking of buying a 1967 triumph 2000 Triumph 22
mailbox Wedge Thinking of parting with project TR7 Triumph 3
bugedd Thinking about learning bodywork/paint Spridgets 35
glemon Spitfire Thinking about a Spitfire Triumph 7
regularman Thinking about taking in another midget Spridgets 2
B Down shifting problems, check my thinking? MG 1
jlaird Been thinking - about time. Spridgets 4
JPSmit I'm thinking of a Vauxhall Viva Other British Cars 10
MadRiver Thinking of selling our C MG 9
M Thinking about buying a 52 MG TD Spridgets 2
M_Pied_Lourd TR2/3/3A I am thinking of installing this in my TR3A... Triumph 13
bugedd Thinking about rebuilding my ribcase Spridgets 16
T OT - I'm thinking about it... Triumph 14
G Thinking of getting a Triumph Triumph 24
C Hello - thinking of buying my first Healey [BJ8] Austin Healey 35
jlaird Thinking out loud, comment pls Spridgets 6
SCguy Wedge Thinking of selling my TR8... Triumph 24
T Weather and Transportation - alternate thinking? Spridgets 43
philman I'm thinking of wood veneer Restoration & Tools 3
sparkydave Thinking about paint Spridgets 8
jhorton3 Thinking Of A Discovery SE7 Rover / Land Rover 5
C I'm thinking its the fuel pump??? Spridgets 13
QuickSilver MGA Thinking About An MGA MG 9
judow Just thinking stage now... Rover / Land Rover 6
P Thinking about getting an XK120 Jaguar 16
M thinking about body work at home Spridgets 19
T Thinking of rebuilding my front suspension Triumph 6
JPSmit So, I was just thinking Spridgets 5
A 59 Bugeye. . .Thinking of Selling Spridgets 7
T I am thinking of selling...... Spridgets 17
DeltaAir423 I got to thinking the other day Triumph 4
T thinking caps required Triumph 59
G Thinking about the stock fan Triumph 7
B Thinking about heat shielding options. Spridgets 9
