Wiring questions
budk1953
I'm getting ready to install a larger fuse panel. Think I've got it all sorted out except for the following;
Lighting circuit brings red/green from the switch to feed reds to various lights. If I were to use a double pole panel (one side constant hot, other side ignition hot)how would I wire this circuit? Or should I use a in-line fuse?
Also I found a brown/purple wire that had been cut off in the harness that feeds the fuse panel and can't find anything on my wiring diagram to tell me what this is for.
Thanks,
Bud
