bob hughes
Hi guys
I have come to the collective ensemble with a small electrical problem and I am sure some one can point me in the right direction.
I have a BJ7 with a Positive earth ( ground ) and it does not have a cut out switch in the boot ( trunk). ( Note to self - must buy one. ) On the wiring diagram there is a white with black wire linked from the switch to the CB terminal of the coil. I am rewiring the car and the existing white with black wire was lurking loose in the trunk and was chopped off in the engine bay just short of the coil. The CB terminal was connected to the dizzy as per the diagram. What is the purpose of this wire, does it act as an electrical short when the cut out switch is activated?, that is the only solution that I can come up with as the car was fine as it was.
Bob
Bob
Hi Guest!
