Stag Wiring plugs for gear lever knob overdrive switch.
malbaby
Looking to do my own overdrive wiring.
I am aware that the overdrive loom can be bought ready made.
Can someone give me the technical name for the plugs that go into the overdrive switch, as I have not been able to source any as yet.
TR3driver
Great Pumpkin - R.I.P
I believe in the US, they are called simply "female quick connects" or sometimes "female disconnect". Sorry I don't recall the correct size offhand, but here's an example
https://www.digikey.com/product-detail/en/63391-1/63391-1-ND/294492
The wire has to be extra small too, to fit through the lever; and I think is supposed to be extra-flexible since it flexes every time you change gears. The room inside the knob is very limited as well. After trying to do my own, I found it easier to just buy that section already made up. Some Spitfires use the same piece.
D distrubutor wiring for 1966 BJ8 Cap to plugs Austin Healey 3
hondo402000 used wiring Harness, plugs wanted Triumph 15
B TR4/4A Wiring Harness Triumph 2
R Wiring ??'s Spridgets 15
Healey Nut Rear Wiring Routing Austin Healey 2
7 General TR Wiring harnesses Triumph 5
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
M TR6 Fuse box wiring mystery Triumph 9
Healey Nut Wiring Harness Routing Austin Healey 5
J Wiring Harness Austin Healey 5
nichola TR6 Question on new wiring harness Triumph 6
R TR2/3/3A 1954 TR-2 O.D. Wiring Triumph 9
TomMull Dash wiring Plus 2 S Lotus 16
MadRiver BT7 Wiring Diagram Austin Healey 4
R TR2/3/3A Replace wiring harness in steering column Triumph 61
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 13
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Sopwith_Camel MGB wiring new Tacho MG 0
Ripper01 For Sale- TR6 Wiring Harness Triumph Classifieds 0
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
Got_All_4 TR5/TR250 Pros and Cons to Wiring The Radio Direct Triumph 6
R TR2/3/3A Wiring from the steering column Triumph 7
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
B Bugeye Sprite Wiring Diagram Spridgets 1
JPSmit Todays question - wiring Spridgets 14
P TR6 Wiring problem Triumph 50
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
M General MG OEM Radio wiring help MG 4
R TR2/3/3A Overdrive wiring installation Triumph 14
ckeithjordan TR2/3/3A Wiring Harness Question[s] Triumph 10
nichola TR6 Victoria British wiring harness for TR6 Triumph 6
C For Sale MGA wiring harness MG Classifieds 3
C MGA Wiring harness question MG 6
JPSmit I'm stumped - wiring Spridgets 2
R TR2/3/3A Wiring 1954 TR-2 Triumph 12
L Wiring chan Austin Healey 1
W Tach wiring problems Jaguar 12
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
Michael Oritt Safety-wiring knock-offs Austin Healey 24
H Re: electrical short wiring damage Spridgets 11
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
R TR2/3/3A Wiring Nightmare Triumph 26
C Wiring for two front Driving Lights? Austin Healey 22
apbos Positive Ground Alternator wiring. Spridgets 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
R TR2/3/3A Installing wiring harness in steering column Triumph 59
6 Relay wiring positive ground Spridgets 4
