"Polarity" for the relay won't matter much, as long as the indicated relay "ground leg" is actually to the chassis ground.
HTH!
Relay is simply a switch - you shouldn't have to reverse anything. But please let at least one person confirm before you act.![]()
Nope. Won't make a bit of difference. Electrons don't know the difference in this case. As long as the indicated (relay) ground lug goes to system ground.
EDIT: The relay coil is an electromagnet, NOT a solenoid. Current flow either "direction" will close the contact.
........apply 12V to the two coil contacts. Then reverse polarity and see what happens.![]()
RUSS!!! Check it out for yourself: Go get a cheezy relay from AutoZone (there's one on Cattleman Road just east of the Interstate, IIRC), skin it and apply 12V to the two coil contacts. Then reverse polarity and see what happens.![]()
Lukens said:And how come you know Cattleman road? Creepy
Randall, that one on the left looks to have taken some heat!![]()
