bmurphy7369
Hello to all,
Still baffled by the ballast resistor...... I have no original Lucas ignition Amp. on the car.
Which wires (ignition start/run) joins to other wires before being plugged into the coil, and which needs to be run into and out of the ballast resistor in the setup (wire colors?)?
I'm not worried about the tach wire for now, just the general setup to make the crane fire the car. Will there be two wires going to each side of the coil, and if so which ones to which connection? I know the red wire from the Xr700 goes to coil pos. and the yellow to coil neg. From there I am lost. Any help appreciated, just need to get the car running and I can re-do the rat's nest later.
Thanks in advance to all!
Brian /bcforum/images/%%GRAEMLIN_URL%%/crazyeyes.gif
