Wireless Question
DNK
I want to add another wireless router to my network. I did some research on the interweb and here's what I got out of it.
1. Need different IP addresses.
2. Need a different name
3.Need to be hooked together.
Here is where I am confused. I have a Leviton Structure Media box with 13 ports on 2 switches. Is this good enough for the hooked together??
I've set up this type of network a couple of times with linksys routers. It was pretty straightforward.
That refers to the 2nd router. You may need to reconfigure it before putting it on the network, or at least ensure it's preconfigured IP is different than the other router. Linksys routers usually all use 192.168.1.1 for example - so if you had two linksys routers you'd need the second to be anything but 192.168.1.1 (192.168.1.2, for example).
You also need to reconfigure DHCP on the new/second router. You might be able to reconfigure the range of the DHCP ports on the two routers so they don't overlap, but I've always just turned DHCP off on the second router and I think that's what's normally recommended. If you manually assign IP addresses to your devices then DHCP shouldn't be an issue anyway.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]2. Need a different name[/QUOTE]
Yup - the SSID for the wireless network needs to be different (I think there are some exceptions to that, wireless-extenders can be configured on the same SSID but I don't think routers can be reliably configured that way).
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]3.Need to be hooked together.[/QUOTE]
Normally all you do is use one of the ports off of one router and wire it to the internet port of the other router as if it was another computer. All it requires is an open port on your existing network. I've never configured two wireless routers to work together wirelessly (maybe it can be done, I don't know).
:iagree:
...and the rest of it, too. :wink:
But I'd change BOTH to be some other IP addy's than the defaults,something in a 192.168.xxx.xxx so they're outside common LAN configuration. Turn ~OFF~ DHCP and learn real Class-C LAN protocol (TCP/IP). And NEVER allow broadcast of a wireless SSID...
...Just my twu sence.
So I started this a while ago.
I also looked for another one where you computer guys recommended brands can't find that one.
So refresh my memory as I will be installing 2 in the new house as I am sure I don't have Cat5 in every room as I had in my last house
Look into this Buffalo for the router, Don.
I've put these in businesses around here and they're good. You may not need a second one.
They use a Linux kernel and have a reasonable GUI front-end to do the admin stuff.
$60 at Amazon, Hey Dave no tax here,
bought. Thanks Doc
