wire wheels
tr8todd
How much work is it to remove wire wheels and the hubs? I just picked up three MGB parts cars and one has a complete set of wires. I want to remove them and sell them off seperately before I send the cars to the scrap yard. The MGs were a throw in in a deal I just made for a 78 TR8 coupe. I heard that you have to remove the axles to get at the rears. Is this true?
The wheels come off with a hammer. Undo the center nut and the wheels pop right off.
The front hubs are held in place by a nut hidden under a dust cover underneath the knockoff. You may want to remove the entire kingpin, hub and all. It would be worth more than the hub alone.
The rear hubs are attached to the axle shafts, which are also help in place by a center nut inside the hub. It's easiest to remove the entire axle and sell as a unit.
Were it me, I'd keep the entire wire wheel rear end complete - especially if its a Banjo.
Looks like I have a project on my hands here. The car is a 72, so it's most likely not a banjo. High temp is only suppose to be in the low teens, so I think it can wait till the weekend. Are the driveshafts interchaneable? If I take out the whole rear end, what else should I remove? Maybe I'll just cut the car in half. The trunk floor and gas tank are clean.
If you have the storage space, I'd pull the complete front crossmember, rear axle and shocks. that would make it very easy for someone to do a wire wheel conversion.
A few turns of a wrench and the whole front end will drop right out. My choice right there.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Are the driveshafts interchaneable?[/QUOTE]
Pretty much.
Hey, you could uild an MGB trailer out of the back half!
As for the suspension crossmember...I've got them stacked 6' high - not much demand for the beam itself!
I all ready own a 72 that is a former race car. From what I gather it has never been registered. It was a showroom stock car for the first five years and then coverted to a flared very modified autocross car. It has been sitting for 20 years and I have owned it for 7 or 8. It needed so much work, that I probably never should have even started to work on it, but I was captivated by its shape. I have since done all of the metal work and most of the fiberglass work. The car only gets worked on when I am feeling very creative. Many cars have come and gone since I first dragged this one home. I picked up a complete 72 parts car with a clean title. When it comes time to finally put a big push into the mechanicals, I should be all set. Unfortunately a flared car will look ridiculous with wire wheels, and I don't realy have the need to keep another parts car hanging around.
Pretty much.
Hey, you could uild an MGB trailer out of the back half!.....[/QUOTE]
Yup like this one
