When things go bad... well... I was doing a routine brake check and was on the last one on the rear when I found that the wheel was stuck to the hub. I tried WD40ing it, then prying gently from the back and smacking the tire with a sledge. Nothing. Add to this the hub is loose; possibly the reason the wheel is welded on. I'll deal with the loose hub later but...
Does anyone have any suggestions on how I might get the wheel off?
