Well, it's coming apart. There is nothing behind the firewall except brake pedal/ clutch pedal/ steering wheel and 2 of the three wiper units. I'm referring to the part that comes through the skin of the car (see picture) The first came off fine but I can't get these two to budge. I've tried heat but only get what appears to be solder bubbling out. Could I have soldered the nut on somehow? (although it wouldn't budge before the heat either.) I've tried 6 days of penetrating oil with no luck. Any Ideas?
thanks
JP
thanks
JP
Hi Guest!
