TR2/3/3A WIPER MOTOR WIRING TR3A
Tinkerman
I have four wires coming out of my harness, two blacks 1 green and 1 black & green. For the wiper motor I see where the green and the black and green go. The ground wire is also OK. So what do I do with the the all black wire?
In my BCF notes I had some info dealing with the issue but no real suggestion as to what I do with the all black wire. It has a spade terminal on it.
Your thoughts and comments, as always, Greatly appreciated.
Tinkerman
Dick, on my wiper motor, the greens go on top, the blk/green is on the bottom, and the black spaded wire goes on the screw terminal towards the frontmost of the wiper motor, the radiator side. HTH!
<span style="font-size: 12pt"><span style="color: #003300">Here's mine. (Post 60,000)
............My harness is original but there is only the one green and the green w/black wires; no double green and no black wire. There is a place marked "E" for earth and the case does show grounded on a meter but no wire. Although the harness is original the motor is not. When I acquired the motor some 20 odd years ago, there was a double male spade where the green wire is now attached, suggesting that there was to be 2 green wires?? At any rate mine works fine!!
Frank </span></span>
On my 59 (TS47905) in addition to the 3 connections on the motor there is also a ground connection under the forward mounting screw for the motor bracket. You can see it to the right of the bracket in this pic:
