bugedd
So I decided to get the wiper motor hooked up, now that I have a switch. After getting it wired up, it turns on, and won't turn off. The switch appears to be working properly, completing the circuit when pulled, and has no continuity when pushed. The black and the black with green stripe are hooked up to it, so that's correct.
At the motor, the three wires and hooked up properly, but what I find odd is that the green (hot) and the black with green stripe that leads to the switch is hot as well. Is that correct? It seems to me that the black/green is a switchable ground, so why would it be hot? As I took the internals out there is continuity between the two terminals, as well as the wires leading to the motor coils. So its all on the same circuit, which seems wrong. Any thoughts on this, what may be wrong, and how to fix it?
Thanks!
Rookie :wink:
Thanks!
Rookie :wink:
Hi Guest!
