A few issues with my wipers on the '74 Midget. They may be separate but perhaps related? Not sure.
1) They will run extremely slow at times. The speed of the wipers seems to go up as I start to drive. I was thinking it could be electrical (varying juice to the motors) or mechanical (sticky linkages that move better if the car is vibrating a bit).
2) They occasionally stay on. Switch the wand back to "off" and they keep moving. If I shut off the car (with key) and then turn it back on, then they stay off. I'm thinking perhaps some relay in the process is failing to "let go".
Either of these two symptoms recognizable to the group wisdom? Related perhaps or not?
