Winter Storage difficulties - kindly comment on my out of the box thinking (?)
twas_brillig
It was the last of the nice days today and we went to put our BJ7 (I've asked for comments on the Healey forum but am here as we also have a BE) into its Car Capsule and - the zipper failed. Tried replacing the slider with a couple of spares with no success. Winter is coming to Calgary starting tomorrow (defined as highs lower than freezing). I'll be chasing zipper slide replacements tomorrow (maybe we did something wrong??) and also looking at portable fabric garages (various problems with our storage space and parking surface will make that difficuilt. Also refer to 'winter is here').
The Car Capsules have been great, as they eliminate the major problems arising from tarping a car: no condensation trapped in with the vehicle, and no rubbing by the material against the paint (yes: the Capsule collapses with snow, but I figure the snow holds the material down so it won't move).
I'm grasping at straws here, and would appreciate thoughts on this particular nutball approach:
- the Healey has a foot print of about 13'x5' (65 sq. ft); a household pillow is about 2 3/4 ft2, and Walmart sells them for 3 bucks Cdn, so for $ 70 I could put a layer of nice clean pillows up against the paint (duct tape them into a blanket if that looks necessary; lay a cloth car cover over them, and then the heavy water proof Car Capsule top 'cover' on top. Any condensation would ideally be absorbed by the pillows and then evaporate when the air is dryer; the weight of the top Car Capsule layer would prevent much movement, and any such movement would be absorbed by the thickness of the pillows.
Calgary is - basically - a high desert in the winter with diddly squat humidity, Chinooks that show up maybe monthly (raising the temperature in 1962 in a town south of here by 70 degrees Fahrenheit in an hour) and suck up the snow but also bringing pretty decent winds.
This started off with thinking of some sort of spacers to keep the water proof layer above the paint for air movement (pool noodles? styrofoam chunks?).
You're entitled to chuckle, but: why wouldn't it work?\
Not sure where the car is going to be located (inside/outside) but I feel like pillows would
1. Be the most perfect bedding mice could possibly imagine
2. not evaporate water - soggy pillows are the worst thing to dry.
I do feel like pool noodles to separate the cover from the body of the car is a better idea though I might wrap them in something soft since the foam is pretty rouch.
Is there an upholstery or shoe repair shop that you could drag the cover to to see about the zipper?
For years I have just used a basic car cover for overwintering Ms Triss - she has always been in a garage and I have never had issues with mice or abrasion (except my own stupidity like dropping things) - assuming you are inside wouldn't a lined cover work just as well?
Outside storage, so ambient temperature. The fully enclosed/zipped up bubble has proven mouse proof. It snowed last night (unexpectedly, for me!) so I'll guess at the size of the Car Capsule and say 18 ft - which means that it weighs about a 100 pounds and the zipper wold be bout 40 ft long. If I was on the coast, I'd stop by and chat with a sailmaker, but we're a wee bit landlocked.
JP: If memory serves, congratulations are in order to Nick Arbuckle and the Argos on winning the Grey Cup. Pretty dang good game. Doug
I missed the memo long long ago!
What purpose does a car cover serve, on a car stored indoors? Seems at the least that moisture would build up inside.
