angelfj1
After working on the 250 this week, in preparations for yesterday's annual Labor Day weekend auto show, "Duryea Days", it is clear that the wiring loom has seen better days. Basiclly most of the terminations are shot and most would need to be replaced. In addition, I am finding that the copper strands which make up the wire are broken in places where you might not expect such damage/deterioration. For example you might flex a wire several inches from the terminal end where it attaches to a dash lamp. The lamp will flicker indicating a bad connection. However, after confirming that the connection is good, the lamp still flickers. I am finding several circuits like this. When I strip back the insulation I am finding broken strands AND corrosion/oxidation under the insulated wire.
How can this be? What are the possible causes?
1. the wire was damaged before it was installed when the car was restored 20 years ago.
2. some agent has reacted with the wire, possibly something in the insulation, thereby weakening the wire.
3. the copper was not cleaned or otherwise treated properly prior to the insulation application.
Regardless of the reasons, what I now have is not acceptable.
I was considering just repairing/replacing the bad terminals, lamp sockets and otherwise places where the continuity is bad. However, considering my inclination for "correct" restoration, and the cost of the correct "Lucas" color coded wire, terminals, bullet connectors, the cost is high and this is a lot of work. So, now I'm considering replacing the entire loom.
Has anyone done this on a 250 or early TR6?
Are all the looms sold by the major suppliers of comparable quality? (I don't want to start a public debate over who's better, cheaper, etc).
Unless you have some general comments or experience/advice, please PM me if you have vendor related comments.
Many thanks
Many thanks
