I'm replacing floor mats. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Nothing major at this point, but I do have a few things on the list.
When out last Saturday after releasing my parking brake the
red dash brake light stayed on. I looked things over on Sunday and found the right rear hanging up a bit. It appears the PO had it adjusted a bit too tight. Loosened it a bit and all seems fine, but the light is still on. I'm thinking it's a bad switch, so I'll be trying that next.
Clutch is a little stiff and pedal is a bit low, so I have a clutch master and slave cylinder kit on order.
Not sure about this one. My front end seems OK but the boots on the upper ball ends have some slight cracking. They're holding grease and they don't seem to be a problem. But I don't believe I have seen just the boots for sale... any suggestions... Should I just replace ball ends too?
Also think I'm going to be replacing the front sway bar links as well.
Last, I have been driving without a hood latch for the last few weeks, but have the new assembly and cables along with an emergency hood release. I have been taking advantage of the last few weekends of driving weather (put 240 miles on last weekend), but this will be the first thing I do once I pull her in for the winter. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
