Same old plan : Drive it till it breaks, then fix it and drive some more ! It's always LBC weather around here, especially for a Stag.
With any luck, the "daily driver wanna be" will come home from the paint shop today. If the looseness in the RF wheel/steering isn't anything worse than worn shims in the inner tie rod, I'm still going to try to hop over to TRfest tomorrow and say Hi to a few friends.
But after that, I plan to pull the steering rack, replace the leaky PS hose, and try to put some feel back into the 'Novocain' steering along with new rack mounting bushings. New Cibie CSR headlights (with new wires & relays), B-post covers & lamps, some new wood for the center console, maybe some tunes. Oh yeah, need to fix the regulator for the driver's quarter window, so I'll probably change the panel at the same time ... the list just goes on and on. I keep hoping I'll stumble across the mechanical temperature gauge adapter that I know is around here someplace, but if not, I'll have to make another one.
