ripvanwinkel
Good Day to All,
After many long years of rebuilding my BN4 LongbridgeHealey, I finally got to the unique little windscreen washer pump that was notworking after 30 years of stagnation. On stripping the unit, I discovered, asmany before me also have, that the diaphragm had hardened and was completelyperished. Many nights were spent contemplating a fix for this as I wished toretain originality in looks and functionality, i.e. a mechanical pump utilisingthe same body and external features.
My first thought was to replace the diaphragm with the cutoff middle finger of a latex glove, stretched over the brass end plate andcomplete with the small internal spring, which was still in good condition.This trial worked reasonably well, but I was concerned that the stretched areawould soon perish and not last the distance. Back to regular contemplation overmany nights!
I then had a Eureka! moment and decided to try the humblelittle squash ball! See pics attached.
This is the procedure I used:
I hope this helps those who wish to retain mechanicalfunctionality of this unique little windscreen washer pump.
- Cut off approximately one quarter of the balland trim/grind the edge as flat as possible.
- Turn the ball inside out and place over amandrel to allow a 1mm wide groove to be machined/ground into the inside faceof the ball, approximately 1.5mm deep and 3mm from the cut edge.
- Reduce the diameter of the brass end plate to36mm.
- Reduce the diameter of the aluminium Plungerplate that makes contact with the diaphragm, by about 1mm.
- The use of the internal spring is optional asthe squash ball alone works a treat, but if you use the spring, reduce thediameter of the largest two coils of the spring to allow it to fit inside thesquash ball.
- Assemble the diaphragm onto the brass end plateusing silicone sealant in the groove.
- Insert the Plunger shaft into the body, followedby the squash ball assembly into the aluminium body.
- Seal the squash ball assembly into the bodyusing silicone sealant and bend over the aluminium edge of the body to hold inplace.
