Windshield Seal Won't Lie Down
healeydan
Just finished putting my BJ7's windshield together and fitting it to the car. Oddly, the rubber seal on the bottom has curled up along its length. Most pronounced in the corners. Would have the effect of an air scoop funneling air into the car under the windshield. How do I get that seal to lie down on the shroud?
Brinkerhoff
If what andrewss suggests does not work then you may have to remove one of the end pieces and pull the seal a bit to tighten it ( re trimming the end of course) then as it is fit to the shroud it will draw down and stretch without the puckers.
I have a bit of this issue with my BN6 too, but just one (1) small area where it's lifted off the cowl__maybe 1" long.
When I received the seal, it was wound up pretty tight, so first thing I did with it was to unravel it, and suspend it from the rafters with a light weight on the end. This helped a lot, but never quite got out that one bump. Not being one to rush into anything__and my own cars are usually the last to get my attention__it probably hung like that for several months...
I too tried the heat gun/tape, as well as rubber dressings (Ghumi-Phledge__it's a German thing) and though better, nothing has been a complete fix. I'm tempted to keep buying more seals from the various sources, until I get one that's not kinked, but if you know how much fun they are to replace, you learn to ignore it!
The first seal I put in seemed to deteriorate within two (<2) years, and I ordered the one mentioned above.
Michael Oritt 100 Windshield seal Austin Healey 0
S Bugeye Windshield Seal Austin Healey 1
Rut Windshield rubber seal Spridgets 6
TR3TR6 TR6 Triumph TR6 Windshield seal on ragtop Triumph 6
H Windshield to body seal Spridgets 9
Rut Bugeye windshield to body seal Spridgets 8
aero3113 100 lower windshield seal Austin Healey 4
HealeyRick Grey Windshield Pillar Seal Austin Healey 19
K TR2/3/3A Windshield corner finishers/seal retainer? Triumph 2
TR3TR6 TR6 TR6 top frame windshield seal. Triumph 5
D BJ7 Windshield Glazing seal Austin Healey 3
J BJ8 windshield-shroud seal installation-found way to help keep ends from popping out Austin Healey 1
J TR2/3/3A Lower windshield rubber seal Triumph 3
M Bn-2 Windshield Seal Paint Bleed Austin Healey 8
maxwedge5281 windshield to shroud seal Austin Healey 2
R TR2/3/3A Windshield lower seal orientation, again... Triumph 9
Lbp TR2/3/3A Question about TR3 Rubber Windshield Seal Triumph 9
M TR4/4A TR4A - looking for a windshield glazing seal Triumph 6
O BJ8 Windshield seal Austin Healey 3
M Sliding bottom windshield seal into groove... Spridgets 2
J Confused about Bugeye windshield to body seal. Spridgets 15
T TR2/3/3A TR3A upper windshield seal Triumph 12
M TR2/3/3A TR-3A Windshield Seal - Top Triumph 2
Nelson Windshield seal installed Spridgets 1
Nelson Windshield seal Spridgets 10
T windshield rubber seal Austin Healey 7
A 76 MIDGET WINDSHIELD SEAL FRAME TO BODY Spridgets 13
Jim_Gruber Pics of Windshield Seal to Vent Window Frame Spridgets 7
H Any tips to install BJ8 bottom windshield seal? Austin Healey 0
bighealeysource Rubber seal on windshield frame of BT7 Austin Healey 0
zimmy progress....... AND my windshield to body seal Spridgets 10
zimmy windshield seal to car Spridgets 12
C Trimming windshield seal Austin Healey 1
Stewart Windshield cowl seal hot tip MG 1
HAN8L1965 Windshield Seal on a 65 Spridgets 5
amcboy TR6 Windshield Seal Question... TR-6 Triumph 8
J Moss windshield to body seal. Austin Healey 2
AndyH Windshield to body seal MG 2
regularman windshield seal question Spridgets 0
judow Windshield Seal BN-2 Austin Healey 6
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
D Windshield to body seal Spridgets 17
Ed_K Installing the windshield frame to cowl seal ? Austin Healey 6
P Windshield Stanchion Seal Triumph 4
bluemiata90 replacing the rubber seal on windshield Triumph 18
P MGB WINDSHIELD TO BODY SEAL & VENT WINDOWS '79 MGB MG 3
T Replacing the windshield seal Triumph 5
SilentUnicorn windshield to body seal Spridgets 15
M TR6 Windshield Trim TR6 Triumph 14
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
