EMGEBE
Hey guys.
As you can see in the above pic, when crusing around in my B, the rear vision mirror around 2500-3000 rpm SHAKES like heck and i know its because at the bottom of the windscreen shaft that holds the windscreen together there is bit of slack and wobbles around 1-1.5mm...
My question is... Is it safe to unscrew the top part of that rod thing, pull the shaft out, whack a dolop of silicone on the end (where it meets the dash),screw it back in, to stop the undesirable movement?
Thanks Jarrod /ubbthreads/images/graemlins/thumbsup.gif
