Can anyone tell me why there is a hole in the frame, next to each of the latch escutcheons? Should they be plugged or are they there for a purpose? Here's what I'm talking about: the hole on the right.
Paul
What was the clear plastic used for your door panels?
If I remember right it was heat shrunk on, giving it a very nice final appearance.
What sticks it down? Does it use a glued edge?
I'm just busting Dale a bit. The heavy duty plastic was cut to fit as a vapor barrier to prevent moisture and water from hitting it.
After the shape is right, spray 3M Trim adhesive on the door (outlining where the plastic will fit) and let it set up for a few minutes. When tacky, apply the plastic and go around it with a heat gun or hair dryer. It smooths everything out and drys the adhesive to a nice smooth water tight fit.
