Woodie
How do you reinstall the outside rubber weather strip , specifically those 6 or 7 bast$%^& clips?? I was able to do the furry side ok.
also
How do you remove the vent window, to replace the rubber under it? I undid the three bolts under it and the 2 bolts on the inside edge of the door.
added later I found this
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=56842
yea sure,, I'll run right out and buy one, ...Not.
Now I know what to make....hmm what to make it out of.???
also
