TomFromStLouis
Perhaps you can help diagnose what my BJ8 needs done to it.
I turn the key and the fuel pump makes pumping sounds. I conclude the battery is fine (which checks) and the fuel pump is fine. I turn the key further and I get an occasional rat-a-tat-tat sound, but the engine does not turn over. I seek the manual, which advises checking for a spark. In doing so, I learn that the solenoid button does not give the same effect as turning the key - no sounds at all. I leave the key turned and return to the engine bay and see smoke coming trailing out from the distributor. I do not know much about cars, but I immediately sense that this is not good. (I have the Pertronix ignition, not points).
I may have done something fresh or maybe the smoking from the distributor is the final stage of my original problem. What steps would you now recommend? Why doesn't the solenoid button work (it used to)? Please keep your instructions at an eighth grade level. Make that sixth grade.
ps - I doubt this is related, but the horn sounds very weak and feeble. It was like this last time I had it out. I am accepting suggestions on this issue as well.
Hi Guest!
