RAC68
Hi All,
Today I attended activities at AHSTC’s Encounter in Princeton’s Forestall Village and on my mainly back road drive home across the NJ experienced some clutch slippage. Although the ambient temperature was only 81F and my engine temperature running at 185-190F, the many Stop-&-Go traffic condition were not unusually high to expect the clutch to stop grabbing immediately and normally.
As I approach the Eastern half of the state, all stops were smooth but the delay in the clutch’s grab seemed to get more pronounced with every start-off. Once under way, however, changing gears seemed normal and any clutch release seemed close, or even, normal with very little or no application delay.
Some Background Facts:
I am using DOT 5 (Silicone) Brake Fluid but see no loss in fluid at the reservoir. The clutch has been performing for the past 20 years and only around 20K miles…if that. I am also using Mobile 1 Synthetic 15W50 and rely on the slinger to keep the oil in the engine (no rear main oil seal).
Last, my transmission is filled with Red Line MTL and the OD is performing perfectly. However originally (20 years ago) the initial MTL fill seeped into and filled the closed solenoid housing of my BJ8 P1 and hydraulically locked the unit. The fluid was drained and all has been functioning perfectly since this remediation
Help:
I would like your thoughts and do not want to over-react as this condition has not happened before and could be an anomaly (disappearing on its own). However, I would appreciate knowing if this condition is recognized by a Forum member and any suggestions on remediation.
Thanks All,
Ray(64BJ8P1)
Help:
Thanks All,
Ray(64BJ8P1)
