ekamm
Decide to work on my TR3 today. Wanted to adjust rear brakes, the handbrake wasn't really doing it's thing. Then decided to check the shoes to see if they needed replacing. And I was curios to see the mechanism never having pulled off the hub. After figuring out how to get the hub off (the work shop manual no help). I pulled the hub and the pad part of the lower shoe falls out. There was a little brake fluid in the drum so I figured that it had eaten the adhesive off. I had an older shoe that came in a box with the car so I wrestled and figured out how to change it. This is where the stupidity comes in, I pressed on the brake pedal to see the action of the cylinder and it moved after pushing a few more times there was a decent stream of fluid coming out and I assumed the seal was bad. When the drum wouldn't fit I noticed that I had pushed the plunger out too far and pressed it back and put the drum and wheel back on after adjusting. Went to drive it home and when I pushed on the pedal it was like bleeding the brakes slow pedal all the way to the floor. Large puddle under the wheel used the hand brake home.
So my cylinder no longer available, no repair kit. Looks like the only option is to change to an aftermarket cylinder and replace both. Is that my only choice?
