Who sells this part?
BG 62AH
Guys, who sells this rubber part for BJ7 & 8's. I have checked around and can't seem to identify a vendor. Any suggestions greatly appreciated. Thank you.
Looks to be something that would come with a new hood (convertible top). I checked my BJ8, and there seems to be remnants of something like that, but I'm guessing they were lost over time or when the hood got replaced. Maybe one of the companies that makes new hoods (Robbins, etc.)? If you locate some please let us know; looks like these would prevent some wear-and-tear on soft parts.
Patrick67BJ8
The "caps" are available from the usual suppliers. Note: you need to trim the center part out of it or it won't fit over the end of the fuzzy seal. The cap can be held in place with clear rubber cement.
number6
Try Macgregor British car parts, on the web.
B
BG 62AH
Thanks for responding. But I am not asking about the end caps for the seal. There seems to be a rubber piece that mounts on the body, and mates up to the seal when the soft top is up. My car came to me as a project, there were a bunch of these soft pieces missing. I only noticed these on a few BJ8s at the Encounter show.
This picture is from a recent restoration from the concour judging.
number6
Bad thing about that site is lack of illustrations, I would give a call and ask them. They may carry them but are not listed.
Patrick67BJ8
The rubber piece you're referring to is probably the Bonnet rubber bumpers. These must be cut to fit. There's variations in the fit of the car where all this cones together so that's why you need to do custom fitting with a razor knife. Bending the aluminum strip that this attaches to might be required to get a good fit. Patience is needed to get the best fit possible to keep the water out.
bob hughes
Yep these are available from AH Spares - item number DRF214, other suppliers may also have them, called a finishing strip, they are a silly piece of rubber mounted on an aluminium strip that is screwed into the inside edge of the cockpit and cantilever out over the gap between the chrome strip and the seal. I have installed mine but I am having trouble with them staying put, the Ali tends to bend when the door is shut and the result looks terrible.
:cheers:
Patrick67BJ8
:cheers:
I got mine to look good but I'm not happy with the fact that they can still leak water inside.
B
BG 62AH
Awesome!!!! Thanks guys. I never did check AH Spares. I really appreciate it. Thank you.
Scot
The hardware for this was still on my BJ8. I just cut a similar piece of rubber with an exacto knife and mounted it on top.
Cheers
bob hughes
Cheers
A good idea. I have been thinking about modifying the fixing idea, but maybe I will take your route.
:cheers:
Proctor
You can also obtain from A Head 4 Healey DR4490 a little cheaper. A H Spares is $19.14. AH4H is $18.56. Each for a pair. BMC No. AHB9930. Top Seal Assy - Shut Pillar (pr). I am in the process of restoring a Phase 2 (41960). I have found if you google the BMC Number you may find a vendor.
RAC68
Hi Bill,
Sorry I didn't see your post sooner. The part is pictured and listed on Moss under the Door Fittings & Seals and listed as for L/H and R/H
803-875$29.99
SEAL, shut pillar, top, L/H
This is a rather simple part and you should be able to find it at a lower price. Although I replaced these metal and rubber bumpers as recently as 2005, I don't believe I needed to modify them and slightly bent the metal fixtures to place the rubber in the proper position under the convertible top's rubber weather strips on each side.
Hope this helps,
Ray(64BJ8P1)
RAC68
Hi Bob,
Sorry but I tried and failed to get a good picture. The rubber section is attached to a longer piece of metal that is mounted with 2 screws onto holes on the inside of the chrome metal surround. The metal mounts place the rubber part in the area were the door weather stripping turns to attach to the top forward portion of the back side interior panel and provides a closure with the bottom of the convertible top's weather stripping around the window with the top is in place.
Of the 4 BJ8s I looked at recently, mine was the only one with the parts installed and the other owners were unaware they were missing. These parts are side specific and I feel the cost (posted by Moss) is out of line with the simplicity of their construction. If no one provides a picture of the installed part, I will try again.
Ray(64BJ8P1)
B
BG 62AH
Ray
Thank you for your help with this. I have noticed that many cars no longer have this part. I only noticed this when recently viewing a concour prepared car.
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
HealeyRick Nasty BN7 Sells for $75k Austin Healey 6
bighealeysource BN7 sells for crazy money Austin Healey 22
HealeyRick BaT Bugeye Sells for $27.5k Spridgets 13
CanberraBJ8 NOJ 392 sells... Austin Healey 10
aeronca65t Wedge TR7 sells....for $82,1000 Triumph 4
toysrrus TR2/3/3A TR3 Door Wood; Who sells them? Triumph 1
G Who sells jet-to-bowl line? Spridgets 6
M TR2/3/3A Who sells seal for early TR3 hardtop? Triumph 6
58Custom Who sells best ribcase rebuild kit? Spridgets 6
TNMGB Mick sells his MG video... MG 5
P Who sells parts for the "other" British cars? Other British Cars 8
E Smolenski sells TVR to American company TVR 14
J RM Auctions 19 Feb Bugeye sells for $23.1 K Spridgets 19
RobSelina Who sells an 11/16" sway bar? Spridgets 11
B P.T. BARNUM SELLS A MIDGET Spridgets 7
Bruce Bowker If it sells for less than $800! Other British Cars 14
P Tiger Prototype Sells at Auction Sunbeam (Rootes) 1
K TR2/3/3A Mystery TR Part Triumph 9
I MGB Help! What is this part for? MG 13
R Part Identification Austin Healey 5
Agrandshort TR2/3/3A Unknown part panel Triumph 5
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
J TR2/3/3A Part Identification Triumph 7
CARSINC Unknown Part Spridgets 5
equiprx Mystery part Other British Cars 2
R TR6 Help: Brake Part Source or …. ? Triumph 1
N MGB Electrical Part Identification MG 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
R Cool Remanufactured Part for Vixen 2500 TVR 7
N MGB Name that part MG 5
D TR2/3/3A Another mystery part(s) Triumph 2
P Wanted Part # BHA5138 Triumph Classifieds 0
AngliaGT MGB Dumb Question - What's This Part? MG 3
D TR2/3/3A Another mystery part Triumph 8
B Useful Part or Boat Anchor? Spridgets 1
R Wanted rib cage tranny part Spridgets Classified 0
B TR2/3/3A Hard Top Part Triumph 2
TR6Canuck TR6 TR6 waist seal clips - which side goes on which part? Triumph 6
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
BritBob TR2/3/3A Part restored TR3A in Oregon Triumph 0
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
Healey Nut Mystery Part Austin Healey 2
Oldi.Tec Spare Part Re-Manufacturing using 3D-Printing Restoration & Tools 5
vping T-Series Looking for TD Part # MG 3
D TR2/3/3A Another mystery part..or two Triumph 14
T Trying to identify a steel plate part Austin Healey 2
Bayless Missing important part Spridgets 0
H TR2/3/3A Rimmerbros Part Triumph 7
