So you've read yesterday's saga of discovering my starter housing is broken and the ring gear "overly" worn.
Full discovery thread.
This morning I turned the flywheel through the entire 360 and all the teeth are about the same. "Slightly" ground down as in the previous thread pics, but apparently still serviceable. Plus, no cracks, etc. visible anywhere on the ring.
There are no screw heads visible anywhere. Previous owner confirms his mechanic emphasized the ring gear was "pressed" on.
So what's the next step?
I'm hesitant to just get my early-style bullet nose starter case repaired, as that starter is likely what chewed the gear teeth. There was no shim (Moss 549-430) used. Per Moss, adding a shim on an early starter brings the pinion further away from the ring gear, decreasing mesh. Maybe the lack of the shim caused the problem in the first place?
In Moss catalogue, the early starter is NA. Only the later starter (TS500001+) is available as rebuilt; early starter is recommended to be replaced by the modern design high torque starter.
Brad at Yankee Auto Electric in Pawtucket (thank you Paul!) is looking to see if he can find another housing. He sure knows his stuff.
Thanks all.
Tom
Thanks all.
Tom
