TexasSprite
My 59BE has a 948 40thou oversize block and a head off of a Cooper S (larger valves). Cam is unknown. The SU carbs on it look like HS1s with the long choke levers parallel to the manifold, but the carb bodies don't have the right profile where they hookup to the manifold. They look like HS2s at that point. The pots also have springs in them.
I have an extra HS1 and HS2 carb sets that I was thinking of having refurbished. Will the later carb work OK on my 948 or should I go with the original HS1.
Hi Guest!
