Which brake fluid?
  • Thread starter Thread starter vagt6
  • Start date Start date
V
vagt6
Just finished overhauling the master cylinder on my MK III Midget. I ran out of the Castrol GT LMA synthetic (pricey) brake fluid from Moss, and no local stores here seem to carry the Castrol fluid.
So, does it matter what brand of brake fluid I use in the Midget? Is it okay to use any premium synthetic DOT 3/4 fluid? Will other fluids eat the rubber bits in the system?
What other fluids do you guys recommend for these cars? Of course, I'm trying to avoid ordering more expensive Castrol fluid, plus shipping charges, from Moss.
Thanks for the help, guys. :thumbsup:
I believe LMA is a DOT 4 but not sure. You don't want to mix DOT 3 & 4. Let others chime in here on DOT 3 or DOT 4
In emergence situations you can mix dot 3 with dot 4 brake fluid however the operating boiling point will drop due to dot 3 has a lower boiling point. Fluids such as DOT 3 are hygroscopic and will absorb water from the atmosphere. Hence, LMA=(Low Moisture Absorption). And the Castrol LMA can be used in Dot 3 or Dot 4 fluid situations.
DOT 3, like DOT 4 and DOT 5.1, is a polyethylene glycol-based fluid (contrasted with DOT 5, which is silicone-based).
Dry boiling point Wet boiling point
DOT 3 205 °C (401 °F) 140 °C (284 °F)
DOT 4 230 °C (446 °F) 155 °C (311 °F)
DOT 5 260 °C (500 °F) 180 °C (356 °F)
DOT 5.1 270 °C (518 °F) 190 °C (374 °F)
vagt6 said:
Castrol GT LMA synthetic (pricey) brake fluid from Moss, :thumbsup:
Can't be more than the $80 a quart stuff my boss uses.
I picked up the synthetic at Advanced Auto, same purple color and doesn't eat my paint, still pricey.
Mark
The purple stuff is DOT 5 or silicone. You definately don't want to mix that with DOT 3 or 4.
This has been a topic many times. In the old days you never wanted to use US dot 3 in a british car or you would ruin all your rubber parts. Castrol LMA, last I used some, was dot 4 and is the stuff you should use. I have completely cleaned the system on a couple of cars and run dot 5. Fitted it to my MGB in the 70's and never had to work on the hydraulics again.
My .02
Kurt.
After a lot of research, it seems that most modern DOT 4 fluids will do just fine in these cars. There's no hard evidence I've found that illustrates that generic DOT-4 fluids will rot the rubber seals, etc. There is some anecdotal evidence, but nothing really convincing.
I also posted this question over in the Triumph forum, no evidence against using generic (non-Castrol) fluids.
Of course, I'm not converting to DOT-5 now, so I'll use "Valvoline Synthetic DOT 3&4 fluid".
We'll see. If anything bad occurs you guys will be the first to know. Thanks for the responses. :thumbsup:
I have not had any problem with the silicone, I do however have all new break lines and have rebuilt the entire system before filling. I am thinking that todays rubber parts stand up to the silicone.
Mark
Mark, I posted my comments to your thread in the Triumph forum.
Mark
You're a little confused there Mark.
Synthetic: All of the brake fluids (Dot 3,4,5,5.1) mentioned are synthetic. It used to be that DOT 3 fluid was incompatible with british rubber parts and had a low boiling point. If all your rubber seals have been replaced then DOT 3 is probably compatible with the newer seals but has lower performance than the other fluids due to lower boiling point. DOT 3 also has more of a tendency to absorb water. Bottom line...DOT 3 is probably OK to use but not recommended...stick with DOT 4.
Silicone: The DOT 5 purple fluid is silicone-based. It is compatible with most rubber seals but is NOT COMPATIBLE with the other fluids. You need to completely rebuild your system and flush it out before you can put DOT 5 in. It is dangerous to add DOT 5 fluid to a DOT 3,4 or 5.1 system and vice versa. That is why it is purple...so you'll know that you can't add it to a system that has non-purple brake fluid.
Mark, Automotive braking is, as we all know, a really important factor in performance car building. The forward thinkers pay an equal amount of attention to stopping as they do to making their vehicles go fast. But, here's a fact that not too many realize: when you step on the brakes, you command a stopping force that's 10 times as powerful as the force that puts the car in motion. Hard to believe isn't it? No wonder the performance brake market has been vying for and finally receiving our attention. But now that they've educated us in the importance of quality components, it's now time to pay attention to the fluid that activates and allows these awesome components to work.
It only makes sense that after you've spent big bucks and a lot of time upgrading your vehicle, the completion of your job must go beyond adding just any old fluid into the system. It's extremely important to always use a high quality fluid. Let's face it, that quart of Elmo's Wonder Brake Fluid and Windshield Washer Solvent combo you picked up at the swap meet may end up as the only thing between the ball of your foot and a brick wall. So, let's at least pay a fraction of the attention spent on choosing components on choosing brake fluid. The following information should help you better understand the differences between various types of fluids.
FLUID REQUIREMENTS
Brake fluid must function through heat, cold, and all the variations of temperatures affecting all brake systems. In other words, brake fluid must be and must remain viscous (fluid) and resistant to severe conditions. It must also absorb water without having an affinity for doing so. Brake fluid must be pure and contain no contaminants, which will have a harmful effect on rubber components. It also should serve as a lubricant for the moving parts in a brake system and be able to withstand time and service--in other words, its boiling point and chemical properties must remain stable. One more important factor is that brake fluid should cause an electrolytic action that will decompose or degrade metal brake parts.
FLUID CLASSIFICATIONS
These factors are taken into consideration by the Department of Transportation, National Highway Safety Administration in Federal Motor Vehicle Safety Standard 116. FMVSS116-classified fluids fall into three categories: DOT 3, DOT 4, and DOT 5. DOT 3 meets the minimum specifications, while DOT 4 and 5 meet more stringent requirements. The purpose of these requirements is "to reduce failures in the hydraulic brake systems of motor vehicles which may occur because of the manufacture or use of improper or contaminated brake fluid." In addition to setting the minimum wet and dry boiling points for all brake fluids, Federal Standard 116 deals with fluid viscosity, temperature and chemical stability, corrosiveness, water tolerance, compatibility (between formulations), and effects on brake system components.
OK, WHAT'S THE DIFFERENCE?
It seems logical that if DOT 3 is good enough then DOT 4 must be better. And, if DOT 4 is better, then DOT 5 must be better still. OK then, why? It all boils down to boiling point. When brake fluid begins to boil (from the heat that's generated in the system during braking) it forms gas bubbles. As these bubbles collect and grow, they form pockets of gas in the system. And since gas is much easier to compress than fluid, these pockets cause the pedal to easily compress or go soft. This is what as known as a spongy pedal--a condition that causes the heart to race.
BOILING POINTS
The following chart shows the aforementioned FMVSS116 minimum boiling points. These boiling points are the biggest difference in the fluid classifications. You'll notice there are two points for each classification of fluid. The dry boiling point is for fresh fluid that has not yet absorbed moisture. The wet boiling point is for fluid that has been in use (or in an opened container) long enough for it to absorb moisture from the atmosphere.
CONNECTING THE "DOT"(S)
The different DOT spec fluids have chemical or formulation differences, as well as boiling point differences. There are (at this point) three commercial formulations for brake fluids; two are glycol-based and the third is silicone-based. DOT 3 brake fluids are a mixture of polyalkylene glycol ether and other glycols (all start life as ethylene glycol--antifreeze); DOT 4 fluids add borate esters to raise the boiling point. DOT 5 is silicone oil based with additives.
SILICONE BASE BRAKE FLUID (SBBF)
The U.S. DOT defines silicone brake fluid as that which consists of no less than 70 percent of adiorgano polysiloxane by weight. Silicone-based fluids are regarded as DOT 5 fluids. They are highly compressible and can give the driver the feeling of a spongy pedal. The higher the brake system temperature, the more the compressibility of the fluid--increasing the feeling of a spongy pedal. Silicone-based fluids are non-hydroscopic, meaning that they will not absorb or mix with water. When water is present in the brake system, it will create a water/fluid/water/fluid situation. Because water boils at approximately 212 degrees F, the ability of the brake system to operate correctly decreases, and the steam created from boiling water adds air to the system. It is important to remember that water may be present in any brake system. Therefore, silicone brake fluid lacks the ability to deal with moisture and will dramatically decrease a brake systems performance. Silicone brake fluid has a number of strengths and drawbacks.
Strengths:
1) It has a high boiling point since it does not absorb water. Therefore, there's no so-called wet boiling point.
2) Doesn't absorb moisture.
3) Doesn't remove paint.
4) The viscosity is more stable over the extremes of temperature.
5) With the exception of some formulations used in external boots, silicone brake fluid is compatible with all standard brake components.
Drawbacks:1) It's hard to pour without entraining air bubbles--hence an application will generally have a softer, spongier pedal feel.
2) It doesn't absorb water, so any water already in the system accu-mulates in the lowest point of the system and stays there, causing rust.
3) Glycol fluids begin to compress near their boiling points, whereas silicone fluids begin to compress at around 300-350 degrees Fahrenheit.
4) Additives in the fluid can vaporize at comparatively moderate temperature, increasing the spongy feel.
5) Silicone fluids expand significantly when hot.
6) Silicone fluid is functionally incompatible with systems that have held glycol-based fluids for any length of time, requiring flushing and seal replacement (there are counter opinions on this, which state that the modern silicone formulations are in fact compatible with only a flushing, rather than a complete reseal). The actual DOT specification requires chemical compatibility, so as far as that goes, the two fluids won't cause reactions if used in the same system, but they certainly won't mix, either.
7) It's pretty much incompatible with anti-lock brakes because the silicone fluids tend to be more viscous, which can cause problems with the timing of the pulses that are intended to work with the thinner glycol-base fluid. This sometimes leads to damage of the ABS valving. The rapid pulsing necessary to anti-lock functions tend to cavitate the fluid, as the tiny bubbles collapse and coalesce into larger ones, and then collapse and reform into smaller ones. This tends to counteract the ABS effect and can diminish the actual effective braking. This condition also heats the fluid and can lead to even more sponginess and possible damage to the ABS controller. Thirdly, silicone brake fluid tends to foam when expressed from a small orifice under pressure, reducing its hydraulic effectiveness greatly.
Minimum Dry Boiling Point Minimum Wet Boiling Point
ll degrees in Fahrenheit)
DOT 3 401 28
DOT 4 446 311
DOT 5 500 356
