Trevor Triumph
Did you again feel the addition to the force? Last week I retorqued the head bolts and adjusted the valves. A friend adjusted/ tuned the carbs, checked the timing, added a restricter to the valve cover openning, and made some adjustment to the distributer cap. It is amazing what can happen when one knows what to do! The cars pulls well throughout the range- off idle to over fourth without complaint.
Still there is a coolant mystery. The temperature gauge shows hot, about two thirds or three fourths of the needle travel. Checked by an infared theromometer all is OK- top of the radiator 177, the block about 199. When the car cools off there is coolant missing from the radiator. I don't notice oil in the coolant or coolant in the oil. There is no aroma of coolant at the exhaust, and no evidence of coolant on the floor.
