disconnect the fuel line at the carb - with someone helping you, crank the engine with the line going into a cup of some description. turn over the engine and see if fuel is flowing.
if it is flowing, your problem is likely electrical. pull a plug, reattach it to the plug wire and lay it on the engine - without touching it, crank the engine and see if you have spark. spark should be nice and bright and you should actually be able to hear it.
It's a '79 Bill so, no points, electronic ignition.
