blkcorvair
I must admit I am not so cooling system savy. It would help I suppose if I could find a flow chart for the Midg 1500 water pump, Never the less here is my question. the 1975 Midg expoansion system was recalled (As I found out just as I was looking to use some parts off my donor car) So rather than try and scavange misc parts from here or there I decided to go all performance. Mainly this car will only see the track anyways. So I have a Moroso Exp. Tank in which the directions state to tap the oulet hose into the inlet fitting of the water pump. I have the tank higher than the water neck and was planning to find a later model water neck (which has a tee fitting already) to attach this too. My thought would be this would keep the system full and do a good job of collecting unwanted air (As the tank is now the highest point) So I am getting impaiteint (I wont have my hands on a later water neck til after Xmas. and was wondering if I could just tee this outlet hose into my heater core bypass tube, if that would indeed give the same affect? My other reason I was thinking I could tap into the water neck originally is because I could in theory use the expansion tank as a fill point as well. (Much more ideal than waiting for the tiny water neck to fill one teaspoon at a time.) If the water neck is the best choice does anyone on here have a 1976-1979 Midget 1500 neck they'd like to part with?
