TR2/3/3A Where to buy steel TR3A battery box?
TuffTR250
I recently ordered a steel battery box from Moss and it came with no brackets on the back for the dash mount connection. I talked to Moss and they explained that is the way BMH makes them. Is there any place to order a good steel battery box that fits well that is complete, and not horribly expensive?
Has anyone tried the battery box from C2CFabrication? The picture on their web site doesn't show much of the box so I can't see if it is complete. Thanks!
Regards,
CJD
I bought from TRF 4 years ago, and it was also missing the brackets. I had to remove them from the old and weld them on the new.
T
TuffTR250
Thanks John! I may need to do that too, but my box is so rusted I'm not sure how good they are. Also, it is hard to tell exactly where the brackets should be welded on. Could you give me the measurements of where to locate the brackets on the box? Thanks!
Regards,
CJD
Here is everything I took as a reference before I removed the old box. The odd one with the wire tab is looking up from below. The tabs are fairly simple if you end up having to fabricate them yourself. That's what I did for the wire loom tabs. What I did for a lot of these trivial parts is I kept all the old sheet metal body parts, and cut them up as I needed to fabricate new. That way i at least got the correct gage metal...
Good luck!
Edit...
Interesting. Recently there was a thread on the overdrive relay mounting. I see the holes for the relay screws were in the battery box for my TR3 (without OD). They were plugged with rubber stoppers. So I guess all the bodies were ready for overdrive. I did not put the holes back in the replacement box.
TR4nut
Yes TRF boxes do have those brackets - a little heavier gauge metal too.
charleyf
The TRF battery box is a good unit. However I have replaced two of these ( different cars) and have found that it is very difficult to remove and then replace the very top portion of the "box unit". This would be the part at the very top that angles back forward and forms the drip rail for the hood/bonnet. If you are interested I will try to show you how I cut the top of the box off and left the original upper part on the car and then welded the box in along that line where I cut it.
Charley
T
TuffTR250
Charley, that would be a GREAT help!! I was thinking about cutting off the top portion. So it would really help me to see pictures of how you installed yours. I'm trying to replace the battery box without messing up the paint and stuff along the top of the bonnet area. Thanks!
Regards,
B MGA Where to Buy, What to Buy? Axle Nut MG 9
B Windshield glass, where to buy Restoration & Tools 4
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
AngliaGT Midget Parts - Where to buy? Spridgets 11
M TR4/4A Where to buy replacement TR4 exterior door handles? Triumph 1
F Spitfire Where to buy Stripe Kit Triumph 1
MY66AH Where to buy a new crank Spridgets 40
B WHEELS- Where to Buy Triumph 4
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
Zitch Leaky SUs where to buy rebuild Triumph 22
D Where in N. Va. to buy/ mounts tires on wire wheel Austin Healey 3
Mychael Where to buy quality pedal rubbers. Spridgets 2
M Where would you buy your next fuel tank? Austin Healey 6
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
60Bugeye Where to buy Bugeye Body Panels? Spridgets 13
T Where buy bullet connectors locally [ie pick up]? Triumph 15
W 90 GL$ Where to buy???? Triumph 12
richberman Where to buy Q-H bushings? Austin Healey 1
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
T Where to buy bolts that secure door latch Triumph 10
B where to buy 175/80r15's? Austin Healey 11
P Where to buy a Parts Washer! Restoration & Tools 10
H WHERE TO BUY A CLUTCH M/C PUSHROD? Triumph 5
hondo402000 TR6 ARP Head stud kit 71 TR6[ Where to buy] Triumph 10
D T-Series Where to buy clutch parts MG 5
soren_ak where do u buy your healey parts guys ? Austin Healey 8
Gerdo Fuel Float? Where to buy? Triumph 8
Geo Hahn Redlines - Where to buy Triumph 3
L Where to Buy Replacement Rocker Panels-Frustrated! Austin Healey 5
B TR6 Where can I buy a trunk kit for a TR6? Triumph 6
M Where can I buy my spouse TR6 things - T-shirts? Other British Cars 4
YankeeTR TR2/3/3A Where can you buy TR2 door wood? Triumph 11
B Need Advice: Where to buy...? Spridgets 1
356roadster brake drums for early 100 bn1: where to buy? Austin Healey 16
J Where to buy aluminum door trim. Austin Healey 3
J Where to buy windshield and rubber parts. Austin Healey 5
T Where to buy Factory Grade Paint? Triumph 6
Z TR6 Where to buy TR6 Soft Top Triumph 7
tr6web Paint - where to buy it? Triumph 3
RobSelina where to buy springs Spridgets 7
K MGB where can i buy mirror for a MGB Roadster 1971 ?? MG 3
V Where to buy headers Triumph 0
Steve Where do you buy tools? Restoration & Tools 14
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
