regularman
I pressure tested the cooling system again today. Put 15 pounds on it for 30 min with no leak down. I even removed the spark plugs to allow more leakage if it was going into a cylinder and nothing, still no leak down. After a drive the water will eventually get low in the radiator and it will overheat. The water never gets low in the reservoir at the pressure cap, just in the top of the radiator and the upper hose will be empty. After I let it cool there will be pressure in the radiator, though it is not very high. I had a motor once that was leaking compression into the water and it did not act like this, in that one the pressure built until the cap leaked water and at the hoses you could feel the pressure. This is not like that. Its almost like the water is not circulating good in one part of the engine and is boiling in there and the water is being changed to steam or vapor real slowly. As long as I keep water in the system it behaves normally, temp goes up when you pull a hill then back down to norm when you get over the top, electric fan comes off and on as normal. I srewed a big funnel into the radiator and ran the motor for about 20 min at fast idle. every few minutes a small bubble of air would come to the top. Maybe something is stopped up and not getting filled with water, Hmmm. This is driving me crazy. I looked at all the plugs and they were tan/reddish as they should be.
